- 110
- 0
Zquez, Anything new to add on you're AST 4150 install? Have you been able to do any more road or track testing? How do you like the spring rate choices you made?
DD GT3 RD said:Jim didn't know about the separate rear adjuster available. I have to look into that.
And as Jim said no modifications needed, as I bought the part for 20. I did not install it. My friend did it for me so not much I can tell you about it. He said it was easy and simple.
cp85gt said:Zquez, Anything new to add on you're AST 4150 install? Have you been able to do any more road or track testing? How do you like the spring rate choices you made?
Zquez said:Once I get my lack of fuel pressure issue sorted out (if I haven't broken anything already) I'll be heading to the track asap.
DD GT3 RD said:3.25 Camber, 0 Toe
ArizonaGT said:Awesome. Did you hog out the top of the strut tower at all, or is that maxxed out?
ArizonaGT said:You go to a GT500 OEM dual pump yet? Don't say "Boost A Pump"!
DD GT3 RD said:They do the alignment by hand too
DD GT3 RD said:went with "Race" spring rates which are 550F/250R
The car is at the alignment shop as I write this so I will see how they set it up and let you know
It will be corner weighted
no bump steer kit or longer ball joints...only other mods I have are the hotchkis rear suspension trailing arms, and sway bars
isrboss said:I am trying to decide on spring rates and with all my investigating I came up with a near 120# less stiffness in the rear. This has been said to be pretty neutral with a square setup. How are you guys tuning out the understeer with the front 300# stiffer? I am guessing an adj. rear sway and dampening, but I would like to hear what you guys are doing.
Sweet setup OP.
ArizonaGT said:Care to share your research with us? Would be a good alternate viewpoint.
JScheier said:I'm running 450f / 200 r with AST 4150s. I do have adjustable sway bars and run a square setup. Car is extremely neutral with a hint of over steer available (at least when a certain installer remembers to shorten the rear bump stops ). I've also run 175# rears and find that the car tends to push a little (under steer) with just the 25# difference.
I'd be interested in seeing your calculations as well.
Just repairing my incorrect statement. I said add a larger front sway if it pushes, but this is wrong. I would need to experiment with front camber and maybe more spring rate in the rear or less rate in the front.JScheier said:I'm running 450f / 200 r with AST 4150s. I do have adjustable sway bars and run a square setup. Car is extremely neutral with a hint of over steer available (at least when a certain installer remembers to shorten the rear bump stops ). I've also run 175# rears and find that the car tends to push a little (under steer) with just the 25# difference.
isrboss said:How much camber are you running up front? I was going to try to set the spring rates so I could possibly drop the rear sway bar off. Then if it pushes, add a bigger front sway bar. Does that sound doable?
