isrboss said:How much camber are you running up front? I was going to try to set the spring rates so I could possibly drop the rear sway bar off. Then if it pushes, add a bigger front sway bar. Does that sound doable?
All of the Boss 302R race cars that I saw this weekend had rear swaybars about the thickness of a spaghetti. Just a data point. I like your plan better, but if the race teams are having to make a minimum weight anyway, no reason not to keep a rear sway assembly that has weight so low and to the rear. For track people not constrained by those kinds of rules, I would also attempt to just get rid of it altogether.
