- 27
- 0
Has anyone raced on this track? If so, how is the track and facility?
athens7 said:I ran on the track last June, right after it opened. The track is technical, with a lot of elevation change. Passing zones are limited, and there seems to be only one line around the course.
Back then there were no facilities (port-a-johns and gravel). I understand it is much better now, with real bathrooms and a light flagging system.
The biggest issue may be sound. Dawson County has set strict noise limits, and the track is very subjective about measurement. If you are running a stock exhaust with the restrictor plates still installed, it should not be an issue.
Smilieboy said:anyone got any events lined up for this?
