Ive been lurking for here for a while. I’ve learned a lot as I build my 1st Autocrossers only Mustang.
I know you all have a lot of combined knowledge on Coyote destruction
. Can anyone tell me what may have caused mine? That’s #8 piston, and valves. Pictures taken with articulating bore scope. Did the piston melt? Spark plug was fouled black. I did a leak test and air only went into the crankcase. All other cylinders are about 180 compression and plugs look ok.
Some specs: Haltech R5, NA engine. Stock crate 1st gen Coyote engine with headers and gen3 intake.
Some history: I bought the engine used from a good track day friend. I knew its history and it was well cared for. Plugs looked good when I bought it and it ran OK. I ran a few Tours and a Pro and it seemed fine. I do know the exhaust cams were not advancing during this time. I sorted out the exhaust cam issues and took it to the dyno to retune. Catch can was smoking lightly during warm up. Smoke increased on each dyno run, till I called it quits on the 4th runs. Smoke was pouring out at that point.
Any ideas on how I can figure out what caused it so I don’t make the same mistake again?
PS: My fix is likely a Gen 3 short block, with my Gen 1 parts bolted onto it.
see pics , Valve picture is is at the BDC after TDC compression stoke.
