OPMustang Tim
Supporting Vendor
ORDER LINK >>> Bamberg Engineering Brake Cooling Deflectors <<< ORDER LINK
These deflectors fit all 2015-2024+ S550 and S650 Mustangs*. 1 Kit per Vehicle.
Includes:
1 Right Deflector
1 Left Deflector
6 Mounting Screws
1 Single Use Container of Thread Locking Compound
1 Illustrated Instruction Sheet
For All Performance Pack, Mach 1, Dark Horse Mustangs these are a direct bolt on.
Simply remove the stock plastic deflectors and install the new deflectors with the supplied mounting hardware and thread locking compound.
For All GT350 and GT500 Mustangs order your kit with the optional threading tap and the installation is the same as above.
For Mustangs that have the Steel Arms, most S550's and GT350's we recommend the High Strength Steel Screws to match the material of the arms.
For Mustangs equipped with the Aluminum Arms, GT500, 2020 GT350R, 2024+ Mustangs including Dark Horse, we recommend the Stainless Steel Screws.
Bamberg Engineered these brake cooling deflectors to maximize surface area for maximum brake cooling, taking advantage of the factory cooling tunnels designed into the Mustang.
These deflectors also incorporate reliefs to allow shaping the deflector for wheel clearance when using Spherical Control Arm bearings that allow the arms to rotate.
These will fit inside all 18"+ wheels. They install in a few minutes and can removed at anytime and do not require any permanent modifications to the vehicle (other than tapping holes if needed)
While ducted brake cooling is extremely focused and effective, it requires permanent modifications to the vehicle and regular maintenance of the hoses due to wear and tear. The brake deflectors are 100% maintenance free.
*For Mustangs that do not have the bosses for mounting deflectors, instructions are provided to source and install U-Bolt clamps for mounting.
Includes:
1 Right Deflector
1 Left Deflector
6 Mounting Screws
