This is the Event Thread for Barber Motorsports Park, 20-21 Nov 21. Discuss the event below.
View full event details here and mark yourself as Going or Not Going
I'm thinking about it if I still have tires Mine are getting thin and new ones are on back order.This is the Event Thread for Barber Motorsports Park, 20-21 Nov 21. Discuss the event below.
Sorry to hear about the car, but at least no one was hurt. You have 5 weeks to get it back together before Barber.We’ll have to miss it. I either broke my shifter or grenaded my transmission in the last race on Sunday at Hallett. Brand new MC is also junk. Have to swap that again.
This was a short session where brake fluid was blowing out around the cover seal and into the driver floor pan. As you can see it also provided enough lubricant to allow the throttle pedal screw to come out. This happened down a hill into a braking zone. My foot got jammed under the brake pedal and I went farming.
After a twenty minute session the entire floor pan was full of brake fluid and running out the drain hole. Scary stuff. After that I filled the reservoirs and glued the cover on.
Sorry to hear about your car woes and glad to hear you're OK. I'm sure you'll have that beast sorted and back on track shortly. Will be nearly a full field at Barber: 132 total today with 29 in I2 and 39 in I1 - with a month to go. CheersWe’ll have to miss it. I either broke my shifter or grenaded my transmission in the last race on Sunday at Hallett. Brand new MC is also junk. Have to swap that again.
I have not run with Just Track It before. How many cars do they pack into a run group?Sorry to hear about your car woes and glad to hear you're OK. I'm sure you'll have that beast sorted and back on track shortly. Will be nearly a full field at Barber: 132 total today with 29 in I2 and 39 in I1 - with a month to go. Cheers
Look at 4dMuscle's post. He said their is already 29 in I2 and 39 in I1. It looks like your at least 40 joke may not be that far off.Sorry to hear about your car woes and glad to hear you're OK. I'm sure you'll have that beast sorted and back on track shortly. Will be nearly a full field at Barber: 132 total today with 29 in I2 and 39 in I1 - with a month to go. Cheers
At least 40…
JK…. I would expect at least 20-25 though.
I might try to make this event.
I’m also going to barber but it is on Nov 22. I found this event with Jzilla. As you know I’m a beginner novice. After reading this I see there are several other event organizer associations. Is everyone here part of Just track it. ? If so can I joinI might try to make this event.
