Basic injector question
Stock injectors are 34 lb. From what I have read, I haven't seen anyone that has replaced these, including the BMO member that setup his motor to the same configuration as the Aluminator XS. Hope this helps.
302 Hi Pro
2,009
441
Southeast
Go here:
https://www.fordracingparts.com/parts/part_details.asp?PartKeyField=22329
Then click on this Ford Service link:
Need help determining which injector you require for your application? Refer to EFI Tech Tips.
Good Luck,
2HP
Hi, Bill
Just wanted to point out that I think the Aluminator XS comes with 47 lb. injectors
In any case, the stock injectors should be fine for the OP
