Best lightweight rear break rotors (OEM size)
129
I am looking to replace the OEM rear break rotors with a lighter pair (slotted or plain only, not drilled) without changing the calipers, just a simple replacement of the rotors itself. My goal is mainly to save weight and a small improvement of braking, but the last one is secondary, my upgraded front brakes do a well enough job on the track.
I found http://www.steeda.com/store/steeda-13-inch-rear-brake-upgrade-kit-for-ford-mustang.html which I will not buy. There is no weight indication and even more, the installation is not what I am looking for. I want only the replace the rotors without doing anyhting on the differential.
I found also those: http://www.girodisc.com/Girodisc-Rear-2pc-Floating-Rotors-for-Boss-302_p_6421.html. Weight reduction for 3.5lb as per the add, not bad but it is a two piece floating rotor and perhaps there is a lighter and better version around.
7,401
4,991
I went with the Girodisc rotors. Lighter, look great
7,401
4,991
Torsion said:
So expensive... worth it?
Not if you are asking my wife. LOL
I replaced both the driveshaft and rear rotors. Power to the rear is noticeably better. Traction from the stop is more of a challenge. So yes, a performance improvement.
There are cheaper solutions.
I have a logic block sometime when it comes to cars. :-[
129
A perfect +1 ;D
Any other opinions/ideas from anyone than the Girodisc rotors?
8,720
2,713
To be honest, the best bang for the buck is just to replace with OEM rear rotors. You can get a pair for $40 or $50 from Roush Overstock on ebay. I run these all day long at the track, I'm still on the factory rears even.
If I were to pick a lightweight rear I would get the Girodisc ones but the cost far outweighs the benefit, IMO.
From a heat sink perspective, I'd want the mass of the rotor to be similar to stock. I'd only want weight savings to come from an aluminum hat.
129
I absolutley agree with you, but here this description fits also well for me: I have a logic block sometime when it comes to cars ::)
Agree and which is the case with the Girodisc as per my understanding: "The central “hat” section of the disc is made from 6061-T6 aircraft specification aluminum. The disc is made from cast iron, constructed in the USA"
