Big air flow leak path between radiator and condenser?
58
87
Michigan
Is this normal, big airflow leak path around radiator? I ask because I bought my car missing the cooling module and had to piece it all together with new parts but I can’t find anything in the parts catalog or assembly manual that indicates I’m missing a part. Seems as if air that passes through the condenser, which is well boxed to the shroud behind the grill, can escape out the side versus being forced through the radiator.
310
Utah
I am surprised the S550 doesn't have anything there as my S197 had stiff rubber flappers on the sides between the A/C condenser and radiator.
Great solution!
Mine was to take out the A/C and box in the radiator. This from a guy that doesn't have an interior in his car... 🤪
