there is nothing needed for 12's. the 13's need this extra tube bracket and modified bezel arrangement.F.D. Sako said:Is your bracket for the 2012s or the 13s?
pufferfish said:there is nothing needed for 12's. the 13's need this extra tube bracket and modified bezel arrangement.
My plan is to cut the fog light tube out with a Dremel. I'll let you know how that turns out.pufferfish said:the next trick is cutting the bezel. it takes a very long saw to cut the fog light tube down. my band saw doesn't have enough opening for it. it takes about 10-12 inches of open blade to be able to cut it. milling it down may be an option, but holding a flexible piece of plastic without any parallel faces is impossible. i believe someone could carefully whittle the tube down, but for me to do it, it wouldn't be cost effective, so i may be offering the brackets without bezels. we will see.
Sorry, the engineer in me rearing its OCD head...pufferfish said:HA! I knew someone would notice that! Good eye! Its just a left over tube I had lying around from the last batch of backing plates.
