Nice...
pufferfish said:short answer is, you have to cut the bezel. and yes, it is definitely worth the air flow. the way it tapers and angles, it cuts airflow by at least 50%. lop that thing off! dremel works well, but by far the easiest and fastest way to cut these things is to use a vibratory saw.
wayne, take a look back at post #56. it has a pic of the modified bezel.Senderofan said:Steve:
Do you have any pictures you can post....of the bezel after you've made your cuts? Really looking forward to this upgrade!
Wayne
Thanks Steve, found some in my cache of screws that worked.pufferfish said:Send me an email. I will send you a new set of hardware on Monday.
WinterSucks said:I had the chance to install the backing plates, was pretty easy. Did pads at the same time. Not looking forward to the duct install. But overall the instructions are great and the quality is there. You might want to think about a rear duct kit, sounds like some of the serious trackers might need it.
