Are there any reports of engine failures on cars without the TracKey? Or are the problems only rearing their head under use with the key? I have 10,000 miles on my Boss and have yet to do the key, and am wondering now if I even want to...
302BOB said:I have over 8200 miles on my Boss myself & haven't got TK yet either. I'm not tracking my car so it feels fine the way it is.
The failures have been with both keys. If you read what the problem is as stated earlier in this thread it should be clear it has nothing to do with TK.LostPony said:Are there any reports of engine failures on cars without the TracKey? Or are the problems only rearing their head under use with the key? I have 10,000 miles on my Boss and have yet to do the key, and am wondering now if I even want to...
Great idea!CaliMR said:If the head lifting around #3 is correct, and is the cause of some of the oil consumption, maybe you could find it early by pulling the #3 plug and comparing it to the other ones. How hard is it to get to the plugs on this motor?
Thanks and I like your license plate. 8)07SGT0547 said:Car is a a Nov 2011 build and is BOSS #2788...
07SGT0547 said:Not the wrong oil... As I have the remaining 1/2 qt of 5W-50 Full Syn Motorcraft oil in my garage...
And while I didn't examine them up close, I did see both plugs #3 & #1 sitting beside each other and they looked pretty much the same...
PeteInCT said:I am still suspect that there is truly an endemic design flaw in the '12 engines,
They only changed a few things in the engine since the first one was built. One is the oil squirters went from steel to aluminum this was probably an issue as to shelf life aluminum will not rust. We do this where I work all the time redesign for shelf life, manufacturability, and cost reduction. heck sometimes it is just for the simple reason of availibilty.
jeepinocala said:PeteInCT said:I am still suspect that there is truly an endemic design flaw in the '12 engines,
Wait. What? Bosses do not have oil squirters.
