Hi all,
Short Version:
My engine is toast. I need to replace it. I currently feel my best option is to find a new crate Gen 2 Coyote engine and drop it in. What do you recommend?
Long Version:
I just returned from a HPDE track day this weekend. On my second session my car lost 90% of its power and wouldn't rev past 5500rpm on my last lap. I looked and saw that my oil temps hit the red mark on the factory oil temp gauge. It felt like a limp mode so I backed off and cooled down for 1.5 laps and then exited. I checked my oil and it was a quart low. Also, I just replaced my coolant reservoir and saw that the brand new fluid had gotten pretty dark at the bottom. I figured the majority of my coolant was old and dirty and i just saw it starting to mix. It may have been oil. I also figured the low oil was from the 6 months since I changed my oil and I may have a slow leak to track down. I topped it off and continued. I should have stopped here and asked more why this was starting to happen.
On my third session mid-way through lap 4 my power started to cut out again for a brief moment. I backed off for a turn and saw my oil temps were high again. I applied maybe 30% throttle on the next corner and it was still limp but a moment later it made a bang followed by metal on metal clanging and a huge plume of white smoke out of the exhaust that filled my entire rear view.
After being towed to my pit I opened the hood and saw my coolant reservoir was empty. I checked the dip stick and it was way too full of thin watery oil. I discussed it with a friend who's a long time mechanic and he told me the engine's toast. No point protecting it now and I might as well see if it will turn over and run enough to get it on a trailer. It turned over twice and permanently came to a stop.
So....
I'd like to know what any of you have done in a similar situation. Some notes:
Video for the hell of it:
I lose power at 29 sec and you barely can hear the sad engine noises at 34 sec.
Short Version:
Long Version:
So....
- I'm not looking for more power. I like the amount it has now and favor reliability for track days.
- It has the Ford Performance Power Pack 3 installed so the ECU is flashed for the GT350 intake manifold and other parts.
- My car has 85k miles on it and is in really good shape
- Most of my modifications are suspension and track oriented.
- My searches for a replacement 5.0 have found mostly Gen 4 and Gen 3 coyotes. Is it possible to swap one of these in and have it work properly with my older analog gauges, hoses, wires, ECU, etc?
- My search for a Gen 2 Coyote so far online haven't been that promising. Does anyone know how to find a new Gen 2 engine to buy?
- What have you done in this situation that I haven't thought of yet?
- I may be interested in doing the replacement myself. I've done most of my work on this car and past car. What potential pit-falls might I encounter? Would you recomend doing it or recommend a shop in Southern California?
- If I drop a Gen 2 stock engine in, will I need to do anything to the ECU since it's been mapped for the Ford Power Pack? I plan to transfer the power pack parts over to the new engine if I find a Gen 2 to buy.
