BNIB Steeda X11 Ball Joints - All 2011-2014 Mustangs
SOLD
I bought these to go on the car (obviously), but never got around to installing them. Now I am thinking of trading the car, so no need for these now. My loss is a bit of a gain for you. Save yourself about 25% off the price of new.
American Muscle sells them for $158. I'm looking for $120 shipped to your door in the lower 48. PP fees included.
http://www.americanmuscle.com/steeda...ints-1112.html
From Steeda's web site:
Steeda's X11 balljoints are a longer, stronger ball joint designed to raise the front roll center of your Mustang which becomes lower as a result of lowering the vehicle with springs or an adjustable ride height system.
Raising the roll center eliminates the issues associated with the lower roll center which include reduced cornering grip, increased body roll, and increased understeer.
Our X11 ball joint will improve handling by reducing body roll and improving the front tire contact patch without increasing spring rate or roll bar rate. You will experience improved steering response and higher overall front cornering grip with reduced understeer as a result.
Steeda balljoints are made in the USA from high strength steel and case hardened to meet and exceed OEM strength and durability standards. All internal housing parts are made from low-friction Nylon to preserve factory steering feel and feedback. Strength testing showed tensile strength to be nearly four times as strong as the OE ball joint.
Designed to fit 2010 GT500, and all 2011 and up Mustang models. These ball joints come with all necessary hardware and are greasable unlike the OE ball joint.
Please Note: 18" wheels are required for clearance. Also note when using the ball joint which relocates the outer control arm pivot point, a bump steer kit must be used with it because the relocation changes the geometry between the control arm and the tie rod ends which increases bump steer. Check out our bump steer kit here.
Product Benefits
  • Raises front roll center for improved handling
  • Reduces body roll
  • Reduces understeer
  • Exceeds O.E. ball joint strength and durability
Bump. If you also buy my Steeda bump steer kit that I have for sale in another thread, I will make you a "package deal."
Also, text or email me for any inquiries, as I forget to check the forums on a regular basis.
256-69 ate - for813
[email protected]
Sorry the pic is sideways. When I copy it from imgur, it rotates for some reason.
