Bolt on sub belt mount for sparco base
I have for sale a bolt on sub belt mount for a sparco seat base for an S550. If you have a sparco base but no way to weld a rod underneath the base to use wrap around sub belts, this will solve that issue. Easy to install, just have to drill four 5/16" holes in sparco base and use supplied bolts to install on the bottom side of base. Rod is 5/8" in diameter and powder coated black. May fit other bases. Total width is 12.5". Can be used with my lap belt mount. $70 shipped for one or $110 shipped for two.
Dinosoar
Dinosoar Motorsports
18
12
Northern Virginia
I have another sub-belt that bolts in at back, along with a lap belt plate. So, I have the rear bolts (upgraded 10.9 and longer) bolting down the adapter, lap belt plate and now a sub-belt bar (3 brackets total) in the the back. It works, but wanted to consolidate (back to two) maybe with just your S197 bar that uses both and all quick connect style brackets.
