I just installed the Bondra Performance Clutch Pedal Extension. The unit is made very well and feels very comfortable when installed. I'm only 5' 7" so this thing saves me from being up on the steering wheel when tracking the car. I was curious if the pedal would fell too high with this extension installed but it doesn't. A fully depressed clutch extends your foot about the same as when the brake is fully depressed, which to me was perfect.
I have one very strong suggestion for installing this unit: The instructions basically state that you should mount the unit onto the pedal and then attempt to put the clutch pedal pad back on the extension unit - DON'T DO IT !! You'll be heating the thing up with a heat gun to soften the rubber and cursing a blue streak ;D The is a much easier way - after you have removed the clutch pedal pad from the pedal, install it onto the extension unit (with each half just held together) first. The first half of the extension unit will slip onto the pad easily. The second will be a bit more difficult, I used the end of a small flathead screwdriver to pry up the rubber lip of the pad and 'flip' it over the ridge of the extension unit. This whole operation only took 5 to 10 minutes and I did not have to heat up the rubber of the pedal pad to get it on. I also did not have to do all this lying on my back under the dash Once you have the pad fully on, spread the opposite end of the extension unit that mounts to the pedal open like a clam. Open it enough to be able to slip it over the left and right side of the pedal mounting flange (that the stock pedal pad was initially holding onto). Once you get the right angle both side will slip over the pedal flange and you're ready to install and tighten the 2 mounting screws. I used blue threadlock on the screws.
