Boss 302 Oil Cooler Leaks
Discussion in 'Drivetrain, Exhaust and Electrical' started by VoodooBoss, Dec 1, 2013.
  1. WinterSucks
    WinterSucks TMO Addict
    1,333
    32
    Oct 29, 2012
    south shore, MA
    Sounds like Ford didn't put their top problem solvers on this one... IMO the rubbing is not the problem. The sway bar hitting a stiff hose is, since it acts like a lever on the aluminum piping, causing the joint failures and quick-connector failures we have seen. I really don't understand why an ME needs an EE to figure this out... The nylon sleeve you mention will just make the problem worse, the sway bar will contact the lines more often due to the extra thickness of the sleeve...
    I fully intend on replacing the stock hoses with flexible hoses that are clamped on. I don't trust Nylon connectors for something as important as coolant lines... I really think the flexible hoses are the solution here, unless the aluminum joint is really that bad that it will leak on its own.
  2. moto
    moto Ron
    241
    15
    May 6, 2012
    Las Vegas, NV
    Same for me this past weekend. Last run of the day after loading up on the trailer so very lucky i guess. 11000 miles and 2 years 10 months.
  3. VoodooBoss
    VoodooBoss Rick Moderator
    19,958
    2,393
    Nov 30, 2010
    I'm glad it didn't start leaking when I was behind you. :)
  4. Tri-bar
    Tri-bar TMO Race
    419
    204
    Nov 17, 2013
    Mines been off the car for a while now, When I talked to Watson Racing. They told me they run a stand-a-lone oil cooler on the WC cars. I'm running the Setreb 924 oil cooler. They run about the same from what I'm told. I'm just worried about the stock one blowing at the track.
  5. moto
    moto Ron
    241
    15
    May 6, 2012
    Las Vegas, NV
    I will most likely remove mine and see how the temps compare with just the air oil cooler.
  6. steveespo
    steveespo Lord knows I'm a Voodoo Child Moderator
    3,381
    607
    Mar 6, 2011
    NY Metro
    Temps will increase. With the stock and Setrab 915 sized matrix running 235-245 oil temps, With a Setrab 934 matrix only I see temps vary from 260-280 depending on ambient temp, length of session and how much rpm I use (7000-7700). I think it is ok and worth the reliability aspect, but am considering a radiator with built in heat exchanger to run in series with the air to oil setup.
  7. moto
    moto Ron
    241
    15
    May 6, 2012
    Las Vegas, NV
    Alrighty, I guess I will hope the new one lasts as that is too high. That's the temps I was running before I put in the Setrab 915 and I like what it is running now.
  8. cloud9
    cloud9 Gary
    6,581
    7
    Nov 29, 2010
    Sioux Falls, SD
    Ron make sure the new one is mounted so the lines aren't getting pushed on by the sway bar. After rerouting mine it has held up for 2 seasons with no more issues..........knock on wood.
  9. moto
    moto Ron
    241
    15
    May 6, 2012
    Las Vegas, NV
    I will. Thanks.
  10. steveespo
    3,381
    607
    Mar 6, 2011
    NY Metro
    Yeah I hear you, I was disappointed too. Ford engineers might know a few things. Anyway this winter the catch word will be "ducting", rear brakes and grille to radiator are the main targets.
  11. WinterSucks
    1,333
    32
    Oct 29, 2012
    south shore, MA
    Are you still using the hard lines from Ford or are you using flexible lines? I was planning on running hose so contact with the sway bar won't act like a lever on the joints at the cooler.
  12. cloud9
    cloud9 Gary
    6,581
    7
    Nov 29, 2010
    Sioux Falls, SD
    Still using factory lines. I'm not sure exactly how my mechanic routed them to gain clearance.
  13. moto
    moto Ron
    241
    15
    May 6, 2012
    Las Vegas, NV
    Ok. I just checked this. I don't see any way to change the actual routing. I thought maybe they might be on backwards but that would make the long one even longer. Both lay right on top of the sway bar as they appear to be slightly too long to stay off it. I am wondering if it can just be zip tied up higher. I will figure it out though.
  14. cloud9
    cloud9 Gary
    6,581
    7
    Nov 29, 2010
    Sioux Falls, SD
    I think that's what he did. Sorry but it's loaded on the trailer up at my warehouse for the Roundup this weekend or I'd go check it.
  15. Swiss Boss
    Swiss Boss TMO Addict
    513
    147
    Jan 13, 2013
    Racing Capital of the world
    I'm pretty sure I busted mine last Saturday at the track (lucky for me it was at the end of the day).
    Is it covered by the warranty? I still got one year left on the powertrain but I got an aftermarket swaybar (Strano).
    Thanks
  16. moto
    moto Ron
    241
    15
    May 6, 2012
    Las Vegas, NV
    It was covered under the 36 month warranty. Not sure about power train. The more I looked at it resting on the sway bar, it is right next to the bracket where it only rotates and there should be no lateral movement so that shouldn't be much of an issue.
  17. Swiss Boss
    513
    147
    Jan 13, 2013
    Thanks. I meant 12 month left on the 36 month warranty
  18. Swiss Boss
    513
    147
    Jan 13, 2013
    Got my car back from the stealarship. Not very happy :mad:
    They told me it was the lower hose leaking.
    They wouldn't cover it under warranty because I had an extra sensor for the oil pressure just above the cooler and saw scratches on the hose and also that I track my car.
    Bringing it with bald tires and no more front brake didn't help either. (replacement parts on order)
    They wanted 576$ to fix it, 58$ for testing the block and 80$ for the inspection :eek:
    Told them to pound sand and will be fixing it myself.
  19. apex32
    apex32 TMO Advanced
    100
    Dec 14, 2014
    That's nonsense. Have you thought about talking to another dealer? Plenty of mod friendly dealers around, but sometimes it takes some digging.
Share This Page
