Boss 302 Owners Map
271
69
Post your "Screen Name" and location on this map using a colored marker pin that matches your Boss!
http://bit.ly/1etq277
Some directions...
Go to the "Additions" tab and select "Add Marker - Simple".
Enter your "Screen Name", Location and then choose your Marker pin color.
Click preview to see your marker location and pin color. Hover your cursor over the marker pin to reveal your Screen Name.
If everything is correct, then click "Submit".
I used yellow for my 2013 SBY Boss 302 LS. :)
Also, for security purposes, I suggest that you only identify your city or general location - NOT YOUR ACTUAL ADDRESS.
batman48195
I never get tired of driving it!
Done. Some directions for others. Go under the "Additions" tab and select "Add Marker - Simple" You can fill it out and then hit preview to see if the Marker is the right color. I used yellow for SBY.
Brian
unit5alive said:
Well I added one some place close to Latrobe Pa , the problem is now I also have a marker in Kansas that needs to be deleted! , help !
I made the same mistake. At first it was "cool! another Boss only 2 towns over!"...then disappointment.
Go to the URL address they said to copy. You can delete the unwanted marker.
http://www.zeemaps.com/edit/AvgRZgUQvoeioSkEvnA2ww
Been there done that. We've been having issues with this but go for it.
https://trackmustangsonline.com/index.php?topic=4104.msg98064#msg98064
271
69
Brian
Brian,
Thanks for adding some directions!
Jim
271
69
Rick,
My apology. I didn't see this previous mapping link as it was located 10 pages deep. Please feel free to lock this thread, but perhaps one or the other map should be pinned so members can see who is in their neighborhood?
Jim
I saw Batmans directions, but since we reside in the same city I used "add marker-detailed" instead of "add marker-simple" under the "additions" tab.
you can put in an address ( I used dealership where I purchased), then there's a link within that window you click on to add longitude/latitude, click on map and long/lat will fill in.
