Boss Side Pipe Delete - Sacrilege?
I am thinking about Kooks long pipe headers and H-pipe catted back to my magnaflow axle-back. I know cooltech makes this setup for side pipes but I may simplify. Is there any purpose to the side pipes besides better sound? Do they help the engine breathe easier? Since I am using my Boss occasionally at work and in the neighborhood, I prefer a quieter sound if that is all I lose.
I am installing Kooks LTs and an H-pipe as well and losing the side exhaust to save weight and to keep the even louder exhuast coming right up in the side windows. That said, I'm not sure you'll quiet it down overall by installing LTs as that will make the car louder. It shouldn't make a significant difference in power whether you go with or without the side pipes.
Sesshomurai
Have it both ways, like me. Install this:
http://www.amazon.com/QTEC302-Mustang-Electric-Exhaust-Cutout/dp/B006IUXF44
Mild-to-wild switch. What could be better?
With the Kooks boss side pipes, you also get this:
No real benefit other than sound and they do add some weight.
I'm thinking about removing them, as well.
Besides, the 302S and R seem to do fine without them. :)
On a related note, I noticed the standard GT has some plastic shields (presumably to protect the fuel tank and/or improve aero).
Worth installing upon removal of the side pipes?
EDIT:
PS - I stole this pic from 5.0 Mustang and Super Fords. I hope that's OK. I am a subscriber if that makes any difference (probably not). :-\
PPS - I don't know why I didn't post this link:
http://www.mustang50magazine.com/techarticles/m5lp_1208_boss_302_exhaust_sides_and_sounds/
I've got the Kooks Lt's, off road x and a Corsa axle back. Mine is crazy loud at wide open throttle but no drone on the highway. I don't miss the side pipes. Sold that setup to help off set the cost.
I think I made up my mind then. Side pipes are going and kooks are coming in. I presume for NA the 1 3/4" are fine. Not sure what the 1 7/8" are for but I seem to recall they had some benefit for FI.
Good to know since I'll have the same setup when it gets here too. Still streetable if you're well mannered I hope? It's hard to stay out of the loud pedal, but I'll probably short shift a lot around town now.
As far as 1-3/4 vs 1-7/8 I was told bigger is better.....
Those are aerodynamic spats. I wouldn't bother installing a set, but they don't weigh much and I'm sure they wouldn't be hard to find.
It's streetable but definately will bother your neighbors if they have sensitive ears. ;D I'm worried it may be too loud for some tracks. Not sure if mine is louder due to the SC or if that makes no difference.
Hey Gary. Evolution told me the 1 3/4" are the way to go for the extra torque. I didn't ask exactly how much extra, but they seemed it was enough to recommend it.
Sesshomurai
LindsayEOD said:
Hmmm. Did they give you a reason why? I've heard a couple of people say 1 3/4 is the way to go for N/A. Evolution was the only one that said you get more torque, however.
The guys at Lethal said the bigger pipes would be best if you intended to go forced induction. I guess it kinda makes sense.
I was told that 1 7/8 you will loose torque unleess you go forced air. 1 3/4 is what you want for N/A. This is so I was told by my local speed shop.
For this power level, I would assume this to be correct. The smaller diameter pipe *should* be better matched for higher velocity flow and scavenging.
Do you plan to get an aftermarket tune or are you waiting to see what happens with the factory tune?
I would probably have Steeda do the install (though someone said in another post, they wouldn't because it's "illegal"). So I would update the tune at Steeda as well. I understand the long tube headers are very difficult to install so I don't feel like taking that on solo.
