Boss Tranny for track
Discussion in 'Boss 302 and S197 Technical Forum' started by Chicane, Apr 5, 2018.
  1. Chicane
    Chicane TMO Beginner
    6
    6
    Apr 5, 2018
    Texas
    I'm looking to upgrade my transmission (12 boss 302) to take more abuse. Only issue currently grinds into 5th gear. I'm taking it to be worked on next week and as long as its pulled I want to do as many quality upgrades that I can.
    Currently installed, Barton Hybrid 3 direct mount shifter.
    Give me your thoughts on necessary quality upgrades, new clutch? new slave? lighter flywheel? carbon fiber driveshaft? Stage 1 upgrade kit?
    Interested to see what the tracks guys have..
    Thanks for your time and help in this manner! :D
    Grant 302 and VoodooBoss like this.
  2. Grant 302
    Grant 302 OPM Spent: $587,402 Moderator
    6,252
    1,385
    Nov 23, 2011
    In the OC
    I'd look up the 'Ben Calimer' internal upgrades too.
    Chicane likes this.
  3. Chicane
    6
    6
    Apr 5, 2018
    Texas
    Thanks for your reply Grant, I did forget to mention that car will stay around 500hp to wheels. Here is example of stage 2 upgrade kit (below). You don't think this is more applicable for 600+hp motors or these are just good parts to upgrade with for the abuse the tranny will endure at the track? Thanks,
    HD 2nd gear
    HD 1/2 synchronizer assembly
    8 - Bronze fork pads
    Bronze shift stop bushing
    2 - 1/2 synchronizer ring packs
    2 - 3/4 synchronizer ring packs
    2 - 5/6 synchronizer rings
    1 - Reverse synchronizer ring
    Snap ring kit (4 snap rings)
    Front seal
    Cluster gear plug
    Output shaft seal
    twistedneck and Grant 302 like this.
  4. Chicane
    6
    6
    Apr 5, 2018
    Texas
    Here is my list that I'm ready to buy anyone care to add or delete item?
    Exedy Lightweight Racing Flywheel - 8 Bolt
    Exedy Grooved Mach 500 Stage 3 Clutch w/ Hydraulic Throwout Bearing
    Ford Performance High Performance Clutch Fluid Line
    3.25 in. Carbon Fiber One Piece Driveshaft
    HD 2nd gear
    Front seal
    Cluster gear plug
    Output shaft seal
  5. RES_22
    RES_22 Rob
    239
    235
    Dec 25, 2016
    Snowy North
    That’s a lot of whp.
    What is your application? Strip or track? Wide race tires?
    Maybe consider Magnum XL before pulling trigger on MT82 upgrades and clutch? Might be cheaper in the short and long run...
    And... don’t discount aluminum DS... very durable and fire-proof.
    Grant 302 and Chicane like this.
  6. Chicane
    6
    6
    Apr 5, 2018
    Texas
    Track only @ 450-500 ish whp...285 squared set-up on tires.
    Thanks for your input!
    RES_22 likes this.
  7. Grant 302
    6,252
    1,385
    Nov 23, 2011
    In the OC
    I think good parts to consider while you have everything apart. There are others here with direct experience with these parts and upgrades. Especially what failed in their original tranny. Luckily, I haven't needed to get inside either of my MT82s just yet. I know this is the direction I'd take when that day comes.
  8. 2012-Boss
    2012-Boss TMO Addict
    630
    221
    Jan 4, 2013
    Have you priced everything above? If there is not a big difference in cost, I would go with a Magnum XL with an aluminum driveshaft.
    Also, unless your transmission builder has proven experience rebuilding and upgrading the MT82 and references to back it up, I would send the transmission to Ben Calimer.
    VoodooBoss likes this.
  9. Swiss Boss
    Swiss Boss TMO Addict
    513
    147
    Jan 13, 2013
    Racing Capital of the world
    My stage 1 from Ben cost me ~1500$ included all the parts that were trashed when my 3rd gear synchro took a crap and a billet support plate.
    Forgot exactly what it's in stage 1 beside bronze fork and shift pad but he has option for ceramic bearings and cryo gear.
    Been running it for almost 2 year now. No problems so far.
    Get a Exedy Hyper single or twin. I got the twin and it's fine for street driving as long you don't get stuck in traffic.
    Install a new OEM slave cylinder and the CobraJet pulse ring too.
    RES_22 and VoodooBoss like this.
  10. Champale
    Champale TMO Race
    426
    62
    Jul 8, 2012
    New clutch for sure (RST/RXT/Exedy Hyper etc) will help with high rpm shifting and eliminate lockouts. If your transmission is already toast, then definitely go with Calimer or something similar rebuild.
    RES_22 likes this.
  11. 2012-Boss
    630
    221
    Jan 4, 2013
    A Magnum XL with driveshaft and speedometer conversion box is about $4,300 looking at current pricing. With a good clutch such as an Exedy Hyper Single, the total price is about $5,500. If this was a heavily tracked car, this is what I would recommend.
    But, this is propaply $1,500 or more than what you would spend on a Calimer stage one with the Exedy Hyper Single and Aluminum driveshaft.
    The Ford line is overpriced. A braided line will work just as well for about $60. You can get the braided line from JPC and Lethal.
    RES_22 and racer47 like this.
  12. BigTaco
    BigTaco TMO Addict
    628
    153
    Nov 27, 2014
    I would not consider the Ford line overpriced. It does not leak like most all of the flexible lines out there. If your going this far, might as well be sure and get a sure thing....
    RES_22 and 302BOB like this.
  13. 302BOB
    302BOB TMO Addict
    4,658
    1,141
    May 4, 2011
    Fairfield County, Connecticut
    BT is RIGHT!!!...You get what you pay for and expect no less!!
    RES_22 likes this.
  14. racer47
    racer47 All I got left is fast
    196
    203
    Jan 8, 2017
    SE WI
    Oh come on it does not take $200+ to make a quality hydraulic clutch line. I've had my $60 JPC for years without issues. It doesn't leak. It hasn't frayed. Its been on and off 3 or 4 times. And its seen higher pressures than most with a Spec 3+ and Exedy 500 clutches.
    ArizonaBOSS and Cruiserfx like this.
  15. TMSBOSS
    TMSBOSS TMO Addict
    3,586
    821
    Aug 23, 2011
    My JPC is going on 4 years.
    Cruiserfx likes this.
  16. 2012-Boss
    630
    221
    Jan 4, 2013
    I have never seen any of the braided lines leak. And I have seen them on a lot of track cars beside my own.
  17. Bill Pemberton
    Bill Pemberton TMO Addict
    1,877
    868
    Sep 30, 2011
    Seeing your HP and wondering what tires you plan on using and would sure suggest more meat to put down your power --- 305s would be great!! All the mods are cool , but think you need more on the ground to really get it to hook up at the max, imho?
  18. gww52
    gww52 TMO Advanced
    127
    16
    Feb 24, 2011
    What do you mean by don’t get stuck in traffic?
    Heavy effort?
    Chatter?
    On/off engagement?
    I’ve got 29000 on my Boss and the clutch is starting to get heavier.
    Lots of track miles so no complaints.
    I’ve narrowed it down to a hyper twin or a Dyad.
  19. gww52
    gww52 TMO Advanced
    127
    16
    Feb 24, 2011
    Why,specifically would you not want to get stuck in traffic with the twin disc?
  20. Swiss Boss
    513
    147
    Jan 13, 2013
    It's a very on-off clutch, kinda difficult to modulate. I always leave a couple cars from the car in front of me before I take off, just in case.
    Also you shouldn't "ride" the clutch too much or you're going to trash the discs pretty quick.
    I'm pretty sure it's heavier than the stock clutch but don't remember exactly.
    It's fine to go to car&coffee and some Sunday cruise but I wouldn't DD my car with that clutch.
    Grant 302 likes this.
Share This Page
