jec246
Build date found on inside your drivers door: 2011/08/09
Do you have skip shift disabled (2011/2012 owners only)? No
Have you replaced your transmission fluid? No
Have you replaced your brake fluid? No
Have you installed an aftermarket shifter? No (Have MGW on the way)
Have you installed an aftermarket shifter bracket? No
Have you installed an aftermarket clutch line? No
Have you installed an aftermarket clutch? No
Have you tracked your car? No
If you've had any warranty work completed related to your clutch or transmission please describe as briefly as possible.
None
Have you removed your clutch assist spring? No
Do you own a Boss or GT? BOSS
None
