I have noticed that many of you guys run the Boss R abs unit-and swear by it, but what about brake bias control? I know in some motorsports abs units, you can interchange the bias valve, but not in the Ford unit. In almost all the road cars we have built, bias control is crucial to tuning the turn in and help with over/understeer issues. Anyone run a dual master cylinder bias box and the ABS? Seems you could do it easily as a front/rear split master cylinder with 2 output lines would basically be the same input to the hydraulic unit as a dual master cylinder box with 2 output lines (one on each cylinder)???
Just some food for thought...
