Brake Duct clamps
ufnavy06
Some say he has a tattoo of his face on his face.
So I picked up the brake ducts used and they only came with 2 clamps. Can I use any off the shelf clamp to replace the ones that are missing? Also, about how long did it take you guys to do the install? Thanks.
Yes any hose clamp should be fine. It took me twice as long as I thought it would. ::) Probably 4-5 hours but I took my time and had never installed a set before.
steveespo said:
Honestly you don't need the clamps at the fascia insert side. I haven't had clamps on there in over 2 years. Makes removing the bumper cover easier when needed.
+1 I've found mine loose on the GT so I've been leaving them out lately. Still holding tight on the Boss which sees less use.
