Brake Noise
jneary
Performance Fords
323
Norcal
Anyone else having brake squeal? I have this when I am applying and also have noticed it dragging when I am driving. A tap on the pedal usually stops it but this is becoming annoying. I have to take it in but with 13,000 street miles, I am wondering how much pad will be left.
Thanks!!!
John
Mine squeal like a freight train but I have track pads in all the time. Even the stock pads squeal from time to time since they are for "light track duty". You can see how much front pad you have left just by looking through the spokes typically. I don't have the stock wheels any more so am not sure how well you can see inside the calipers. If you're concerned just pull a wheel and look inside the calipers to check pad depth. The rears should go 10s of thousands of miles unless you happen to forget to disengage the parking brake ;D
