KNS Brakes
Supporting Vendor
Close but don't think so.
+1NFSBOSS said:Very nice. I look forward to your feedback but my wallet doesn't.
steveespo said:Nick
It looks like the Caddy pad but Van at Revan said its not. I will trace my pads and measure as many details as possible. I don't think Ford would have created a proprietary pad for this caliper but who knows and it doesn't seem like anyone is talking. I have posted this question on 4 real enthusiast sites that I know Ford and racing people frequent and haven't gotten any good info. I bet next year these parts will be part of a track pack for GTs, production costs have to be amortized somehow. Road Runner will appear in another model too.
steveespo said:Pete
The calipers from the 2013 GT 500, 6 piston Brembos. I can't find a pad shape or an advertised race pad replacement anywhere yet. If you haven't seen it I posted the shape with dimensions in my earlier post.
steveespo said:Pete
Rick
Here is the definite upgrade,side by side comparo of the pads, much more surface area to distrubute brake force and dissipate the heat generated. Has to be an improvement in durability if not specific 1 stop 70-0 or 130-60 performance (I will try and check) but consistency over a full session should be improved. Stock pad surface is 60x128mm=76.80 sq/cm, GT 500 surface area is 65x158=102.70 sq/cm. it is a 33% increase in pad area.
As far as the hoses, I matched the stock Boss hose against the stock GT 500 hose and they are different, the length is the same but the bend at the banjo fitting is about 45 degrees different, I forget how the goodridge banjo end is but it probably is the same so I will have to run the OEM hoses untill I can get a Goodridge specific line.
