cloud9
Gary
Looks great Steve. I am guessing this is something I will want given the fact that the rotors have been a limiting factor for me at this point. More mass has to be a good thing. I will be very anxious to see how they work for you.
06mach1 said:The size of the pad is one thing, but you still need brake fluid volume and pressure via the master cylinder. Without that, it does not matter how big the pads are. Sure would be nice to have the hydro boost system.
KNS Brakes said:If the piston area is more than pedal travel will increase because the force multiplication changes (area of MC/area of caliper) but the larger rotor increases the effective radius and thus brake torque.
That matters - but the primary gain is mass and surface area to manage heat better. The brake pad is the fuel and the rotor and caliper are the radiator. All of it got bigger.
Thanks Ken, That is from the Brembo Catalog right? Do you know what Carbotech charges to reline plates, As much as I would hate to do it I would buy another set of pads and have it done if the cost was close. As far as the HB 616/WVA08355 shapes they do look like they would fit just expensive. I have no intention of going cheap at this point but if I commit to something I want to be sure it will work,KNS Brakes said:
This one is pretty close.
KNS Brakes said:It will change bias.
Brake torque at the wheel is proportional to the effective radius of the pad/rotor. If you increase rotor diamter - you increase the lever arm of the pad area thus increasing brake torque.
It's a stroked version of your brakes.
So you will be front biased some.
Not sure about the ABS thing as much unless there is a brake force distribution circuit in the car as that would be mapped to some extent to react to wheel speed inputs.
Pete I have tires in both 26 and 27" diameters, both front and rear. I can mix and match to tune gear ratio and rake. You are right though I wouldnt want to run the front tires 680mm and the rears 660mm.PeteInCT said:Sure you want to raise the front 1/2 in compared to the rear?
Been here too, I run the 14" Baer rears with their relocation bracket and stock calipers. Don't really know how much it helps but they fill out the wheels better and I haven't had any strange ABS intervention on street or on track.KNS Brakes said:It will change bias.
steveespo said:Been here too, I run the 14" Baer rears with their relocation bracket and stock calipers. Don't really know how much it helps but they fill out the wheels better and I haven't had any strange ABS intervention on street or on track.
Mark posted in the other thread that the BBS 302R/S wheels fit over those brakes. So you could still run 18" wheels.steveespo said:Update; I just mocked up the caliper/pad/rotor assembly and tried it inside my 18" SVE Drift wheels, No go even with caliper pushed down onto the rotor the setup wouldn't clear. Looks like I will be running Boss 302S 19"x9" up front. I guess I can run my 18" rears, will call my car "FrankenBaus" with that configuration.
2012YellowBoss said:Thanks, so you think it is a bad idea just to slap on the bigger rear rotors and brackets without any other changes?
