for me the shifts became much more solid. I have done any WOT shifts from 4th to 5th at redline though. but it did make a noticeable differenceFlyboygsxr said:Just a thought...did the more rigid motor mounts help with the shifting problem our cars have? Mainly getting it into 5th gear at speed which I believe is the result of a few different factors but one of them being the movement of the engine and tranny when torque is applied.
cloud9 said:I know what you're thinking, and no I haven't been driving Scott's car.
steveespo said:I am right that the engine rotates clockwise when looking from the front and it torques over towards the passenger side? This would cause the drivers side mount to be in tension and the passenger side in compression under load.
The engine mounts help me find the gears better because they are moving around a lot less. The gear engagement didn't change at all. Fifth gear still doesn't like to be rushed, especially above ~110.Flyboygsxr said:Just a thought...did the more rigid motor mounts help with the shifting problem our cars have? Mainly getting it into 5th gear at speed which I believe is the result of a few different factors but one of them being the movement of the engine and tranny when torque is applied.
YellowBoss said:Maybe but is the tension in the passenger side mount compressing when you are spinning counter-clockwise on a left hand turn track in the grass and on pavement? Or would you have to spin clockwise on a right hand turn track? ;D
loco pantelonez said:I could be wrong here, but it is possible that the lower bolt came loose and fell out? The reason I ask is that it is hard to see any damage besides missing parts in the picture. The lower side bolt on my driver side mount fell out and looked just like this. Luckily the k member "caught" the bushing and metal washer that I was able to fish out and reuse.
ArizonaGT said:I think I will wait to do this mod until more conclusive evidence and track use exists...
