Chuck,
I'm putting in the Ford performance swaybars. Looks like you have the blue ford racing rear swaybar. I can't get mine to fit with the MCS shocks and adjustable endlinks I have. Do you have a picture for what you used? What endlinks do you have. I think mine need to be longer than stock and the end of the bar moved very close to the spring. With bar end of endlink installed the spring hits the head or the threaded part of the endlink. How did you solve this? Also the middle of the bar articulates pretty close to the front of the tire well and can squeeze diff cooler lines if the routing is just so. Have you checked yours?
Also, Lots of guys run the FP front bar and PP1 soft rear bar. I think it is because of chassis rake that they like this combo. Most people measure rake at the end of wheel to the lip of the fender for about 1/2" rake. I measure from bottom of frame rail not including the pinchweld for target of 1.4" to 1/2" rake there. After I set my rake at the frame the rake at the fender lip is actually negative rake. My way would make sense because then the thicker rear FP bar causing oversteer at higher rear of car is compensated for because my way the rear of car is much lower to counter the OS of a heavier rear bar. What do you think of that?
I have always relied on the kindness of strangers running the same car as to my setup. I just drove. Now no one around me racing the s550 especially A10 so I'm forced to develop. It is a real pain and costly. Stuff adds up like buying standard rear endlinks and then dumpping them for more. Same with more spacers. And my destruction of tires has been impressive.
Well, we'll help each other as much as we can. As soon as I hit the track i'll make sure to give you some feedback. Please do the same! Lots of trial and error for me too, but I learn a lot here.
have you put your car on a proper setup pad for corner weight and alignement?
Yes. This is the 2nd time scaling the chassis and refining ride height. I have run about 6 race weekends and constantly developing and learning the chassis.
That is WITHOUT driver?!
Wow my goal is 3,300 with driver, I guess it's going to be impossible.
No with driver and 50% fuel load min weight off track 3600 by rulesThat is WITHOUT driver?!
Chuck, everything seem straight forward with wiring the pump and fan? Where did you spice everything in?Perfect, i’ll do that asap!
in the mean time,I notched a little metal lip on the subframe to give the top hose a little extra clearance, and some peace of mind. The diff is not mounted 100% solid so there is still a little bit of movement. It gave me a good 1/2 - 3/4 inch clearance.
Oh man, those look so good painted! Did you have them painted to factory paint code? I'm worried the colors would be slightly off and end up looking worse than just black but they look amazing in these picturesMore updates!
Did some work on the front fenders in an attempt to help 3 issues I had with the car. In theory, these louvers from race louvers will help all 3:
- Help the front downforce
- Help with cooling the engine
- Help with cooling the brakes
I'll make the hole in the rear of the fender liner and cover it with a aluminium grille. if it does not help anything, well at least it will look kinda cool.
Good to hear.I just picked up a can of factory colormatch paint at my auto parts store. The match is just perfect.... for a race car! When I get the thing all stickered up they're going to blend in, that's what I was going for.
Back in my 56 Chevy drag racing days, I removed the inner fender panels to save about 150 pounds, worst thing I ever did, the car literally "floated" on the big end, it was really sketchy and hard to control. In my nearer years, a trick with the MGs were to vent behind the front wheels as well, we also did that with the laydown karts, along with rolling the back fender lip. Now running the inner fender should stop most of that, but I don't see where it would hurt to have a little extra "insurance" to make sure the air stayed from in front of the firewall. Now none of this is tunnel based, it might even be wrong, but it makes sense to me. Someone smarter may have to explain it better.Looks great Chuck.
Really curious to hear some real world feedback on these vents. Information seems sparse.
Help me understand: how do fender vents in theory help with engine cooling? This would imply that relatively high pressure in the fender well is backing up into the engine bay? How is that (or through where)? Seems with a ducted radiator the migration of air between the engine bay and wheel well would be pretty minimal?
