- 44
- 0
Right now I am lowered on eibach pro kit springs. After i installed them I got an alignment and my camber prior to the alignment was -1.6 so I went and ahead and installed camber bolts to bring the camber down to a more reasonable -0.8 for street driving. But now I am tracking the car alot more and I am wearing out the outside shoulders of the tires. I want to run at least -2 or -2.5 camber now. I was wondering if that would be possible using the camber bolts, and still have the caster and toe set correctly?
The car is also a daily driver which is driven about 35 miles per day but it is tracked at least once a month. So my thinking -2, -2.5 should give me even tire wear, and help with handling a little bit.
I have the stock struts/shocks right now as well and may upgrade them in the future. So I dont know if getting caster/camber plates would be worth it, I was also looking at the steeda and maximum motorsports ones.
Any help would be appreciated, would also be interested in hearing your set ups and how it works for you.
