Camshaft sensor differences between '12 and '13 ?
PeteInCT
2,848
14
I've been told that one of the changes between the '12 and '13 Boss was the camshaft sensors. Does anyone have any finite evidence of this ? I am curious if they did make a change in '13 and if it's solely a connector change or if the whole sensor (including the connector) is different. Rumor is that there was at least a connector change (hence, '12 engine wiring harness won't work on a '13) that addressed bad connectivity issues due to vibrations from the engine. I am still having problems with P0300 codes and limp mode and am curious if the sensors may be the cause of the problem.
PeteInCT
2,848
14
BOSS343 said:
You ever get word on this Pete?
no I was never able to find out exactly. I suspect it is only a conectar difference. However, the sensor part number will be different solely because the difference is the connective it has. I suspect the actual specs of the sensor itself we're not changed. The harness is also a different part number because of the connectors.
PeteInCT
2,848
14
Yes, they added orings to the same crankshaft sensors. I was questioning if the camshaft sensors were different in the '13s other than the connectors on them
