This is the Build Thread for 22 Mustang GT PP. Reply below.
Nice !! Don’t forget your toe-in settings, front and rear. Have a great time at the track as Carol looks like she’ll take good care of you as long as you take good care of her. You have the brembo front 6 piston I see, so stock pads ? I’m using the Ford MR3Z-4001-C front pads and they work well for me. I get a season of 12 to 14 events out of a set of fronts and 2 seasons for the rear pads. Don’t forget also to remove your wheel center caps, they’re plastic and will melt with track duty, literally falling to the inside of center hole. Welcome to the forums !!Finally finished installing the upgraded suspension pieces this past weekend. Installed FP Track dampers paired with BMR Handling Springs as well as some Maximum Motorsports camber plates. Did everything in my garage on jack stands and took my time over the course of a few days. Brought it in for a performance alignment at a shop close by and went with -2.5 camber up front and -2 camber in the rear to start. Installed some Steeda IRS braces a couple weeks prior to this but haven't been able to test them with any sort of aggressive or track driving yet. I wish that I did some IRS subframe bracing while I was doing all this since I ended up having to loosen up the subframe anyways in order to get the stock rear springs out, but you live and you learn...
Was also able to finally procure some Goodyear Supercar 3 tires that have been out of stock everywhere for months. Was considering Hankook RS-4's but they don't make them in a 285 width and I can get a 25% discount on the Goodyear's via USAA. Tires were mounted on new Apex EC-7 19x10 wheels all around.
Will be testing it out at NJMP Thunderbolt on Labor day. Looking forward to seeing how the better suspension, camber, and wider square setup compares to the previously stock Performance Pack setup.
