Check Charging System Message
Discussion in 'Boss 302 and S197 Technical Forum' started by cloud9, Jun 2, 2012.
  1. 302 Hi Pro
    302 Hi Pro Boss 302 - Racing Legend to Modern Muscle Car
    1,707
    183
    Dec 10, 2012
    Northeast
    Yes, the voltage regulator is an internal part of the alternator, and I agree with you, as high RPM's and heat are tough on regulators.
    Glad you got it fixed,
    Hi Pro
  2. TMSBOSS
    TMSBOSS TMO Addict
    4,253
    1,355
    Aug 23, 2011
    A competent build shop should be able to repair the original and save a few bucks.
  3. gww52
    gww52 TMO Advanced
    143
    21
    Feb 24, 2011
    I’ve got the battery light and check charging system.
    PO626 code.
    Scanner diagnostic said regulator high voltage.
    The Pid showed a fault.
    Changed the alternator for a brand new OEM and still have the battery light on and off.
    Anyone have this?
  4. 12coBoss
    12coBoss TMO Intermediate
    91
    41
    May 20, 2013
    Omaha, NE
    I never threw a code, but had the battery light and check charging system message. Swapped alternator and have been good since.
  5. gww52
    gww52 TMO Advanced
    143
    21
    Feb 24, 2011
    I'm still having intermittent check charging system messages but only on track or as soon as I pit.
    Changed the alternator last spring and was good until fall at WG,message code at pit in on the last session.
    Seems it has to be heat related somehow.
  6. Swiss Boss
    Swiss Boss TMO Addict
    530
    195
    Jan 13, 2013
    Racing Capital of the world
    Check the wiring at the plug. I had 1 of the 3 wire broke right at the connector.
    Car was throwing P0625 code when it was happening.
    Soldered a pigtail found at AutoZone, don't remember the part number, and it's been fine since then
    Mad Hatter and Grant 302 like this.
  7. gww52
    gww52 TMO Advanced
    143
    21
    Feb 24, 2011
    Thanks Swiss Boss,I'm going over the wiring this week.
Share This Page
