Boone
Professional Thread Killer
I currently have issues with the rear 8.8 axle in my '05 GT. I have 3.55 gears, Eaton TruTrac, stock single piston brakes, and it is adjustable at every connection to the frame. Issues are a leak at the pinion seal, a leak at the passenger side axle tube at the pumpkin, and a general lack of confidence in the assembly.
I'm going to replace the whole axle as a unit, and advice is needed:
Stay 8.8 or figure out a way to get a Ford 9" to work?
Gears are going to 3.73 (high revving NA motor)
Stay with TruTrac or go Torsen?
Rear brakes - can I go 4P, and what parts should I procure?
Where do I get it? (I contacted East Coast Gear Supply in Raleigh, NC for an estimate)
I want this to be the last time I dig into this axle assembly. Also, I have the ability in the future to add a supercharger that could put me in the 800whp range, so I need some strength (but I won't dial it up that high, maybe 600whp on relatively low boost). I use the car for autoX, HPDE, and days where I just want to hear the rumble.
Thanks for your wealth of knowledge and willingness to spend OPM.
