Register Log in
Check Your GT350 Oil Filter!
VoodooBoss
Rick
Messages
21,326
Reaction score
3,643
Location
There was an incident at a recent track day in Colorado where it was confirmed that an oil filter came loose on track. The owner had recently had the oil changed and the oil filter O Ring was "partially blown out". To me that sounds like the filter may not have been installed correctly. The special oil filters for the GT350 have thread locker in the threads and has a higher torque value than a typical oil filter. Hopefully someone will confirm this but I believe it's 18 ft lbs. If you're not changing the filter yourself I'd make sure the person doing the work knows how critical proper installation is. Oh and remind them that it takes 10 quarts of oil. I know that one from first hand experience. ::)
Black Boss
TMO Addict
Messages
1,874
Reaction score
1,685
Location
Michigan
16-18 ft lbs. That's way more than the S197/ Hand tight and needs a torque wrench. I've changed mine twice and have had zero issues with 7 track days.
cloud9
Gary
Messages
6,580
Reaction score
7
Location
Sioux Falls, SD
Dealer told me torque spec was actually printed right on the filter. I had them dump the oil while installing the camber plates so haven't changed it myself yet to look at the filter.
8250RPM
TMO Addict
Messages
565
Reaction score
161
Location
South East Michigan
Correct it is 16-18 ft lbs. But being a mechanic myself I've seen incidents where the old gasket will come off the oil filter and still be stuck to the filter gasket surface on the engine. If this happens the new filter will not seal and oil will blow everywhere. Always check to make sure the old gasket is removed before installing the new filter.
krt22
TMO Advanced
Messages
179
Reaction score
Thanks for the heads up, I just ticked past 1000 miles so I'll be doing mine this weekend
tigerbillsbikes
TMO Intermediate
Messages
36
Reaction score
Location
Suches, Georgia
I just changed my oil last weekend for the first time. Dang, the filter was nearly impossible to get loose. During the process I almost destroyed it. A lot of foul language involved. Is there a special filter wrench I should get?
In addition, I was really surprised at the twist off plastic drain plug. I found nothing in the owners manual regarding removal and re-installation of this thing. Is anyone else worried about this thing
getting loose and possibly falling out? Perhaps I worry too much. I may be living in the past but I sure like a metal plug in with a washer that screws into a a metal pan with torque specs. Would love to hear from you folks that do your own oil changes.
VoodooBoss
Rick
Messages
21,326
Reaction score
3,643
Location
I bought this wrench:
http://www.amazon.com/DEDC-Filter-Wrench-Socket-Rust-resistant/dp/B018NMV7X0?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
The external magnets are an interesting idea. Which one did you order? Will the SS300PR fit?
http://www.summitracing.com/parts/ftm-ss300pr/overview/
Here's another option:
http://www.amazon.com/Universal-Filter-Magnet-Protect-Performance/dp/B016H588VE/ref=pd_sim_263_3?ie=UTF8&dpID=5106IhVThML&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=1AT9M0GG3XENR0YRDRVF
tigerbillsbikes
TMO Intermediate
Messages
36
Reaction score
Location
Suches, Georgia
Thanks for the info and I may order the oil filter removal tool and magnets. Before removing the original filter I did take my new filter to the parts store and bought a filter wrench that fit pretty snug to the bottom of the new oil filter. It wouldn't budge the filter on the car. It simply slipped around the bottom of the filter doing no good.
Does anyone actually use a torque wrench when tightening the new filter?
Also, the drain plug sure seemed kinda wiggly when it was tightened causing concern.
I wonder how often the seal on the plug should be replaced?
Maybe I worry too much about stuff.
Tob
TMO Race
Messages
206
Reaction score
64
Location
Upstate
This exact same thing just happened to one of the GT350's at the Track Attack. Driver was at speed but managed to get off the track after spewing quite a bit of oil on the tarmac. This was yesterday. I went back to the track today to talk to the management there about a couple of things and I saw the car parked near the garages with the front end up in the air. Oil had sprayed the undercarriage pretty good. The staff there confirmed that the filter had come loose and then the seal or o-ring blew out.
mattlqx
Mustangless
Messages
453
Reaction score
205
Location
Chandler, AZ
Wow, I bet they'll be checking the filters more than just between oil changes in the future if they're not already.
shelbyman1
TMO Intermediate
Messages
34
Reaction score
Great info here. I'm getting close to changing my oil and filter so will get these products for when I do. Thanks much. :)
shelbyman1
TMO Intermediate
Messages
34
Reaction score
VoodooBOSS said:
I'm not too worried about the composite drain plug but I'm with you that I'd prefer a metal one with a magnet. I wonder if they could have used a metal insert for a metal drain plug?
I'm going to be doing my own oil change soon and was wondering if there are any tricks to getting the drain plug out or reinstalling it? Thanks.
Flyboygsxr
ADAM
Messages
962
Reaction score
29
Location
Texas
You can almost screw it out with your fingers it's so easy to remove. Just use a 3/8 drive with an extension and it comes right out...be ready though because those 10 quarts come out fast. Doing an oil change in the is car is a breeze. Make sure you have an oil filter socket and a torque wrench. I bought the oil filter socket on Amazon.
