Complete Brake Job - Rotors/Pads/Lines
We got this local owner in to do a full on brake job.
(Ignore the silly red car....)
First we will get the front pads out. Use a suitable punch to knock the pad pins out. Then remove the pins and cross spring.
You should then be able to wiggle the pads out - pull them back a bit if there is a big lip to get over.
The arrow on the shim is for direction of rotation.
Remove the bolts holding on the caliper. Pretty tight 15mm head.
Blue loctite!
Hang the caliper out of the way and install the new rotor. DBA 2 piece - pretty!
Reinstall the calipers - 85 ft-lbs and blue loctite
Here is the tool we use to push the pistons back
Or in a pinch you can pry back w/ a used pad.
Note - Leave the other pad in so those pistons don't push out.
Re-install pads and pins/cross spring. Make sure the pin detent seats securely.
It's easiest to do the lines separately when it's all back together. Just re-do what Ford did w/ the new lines.
Remove/install the lines. The Stoptech kit was quite complete to mimic the secure factory setup. You remove the factory bracket - you do have to finesse the line to attach to it - but then they have a neat isolator setup to hold the lines.
Get a line wrench - and don't overtorque.
Lunch break!
3,761
1,244
NY Metro
Got my 15" GT500 specific Carbotech XP24 Pads from KNS yesterday, perfect, increase in pad material over the Lexus 14.3" shape I have been using has to help with both torque and temperatures. Very pleased that CT got these out finally.
Does anyone know the specs for the banjo bolts? I just had a fun time installing lines and trying to use Fords spec of 41ft/lbs.
