What do you guys think. My current daily is BRZ with blizzaks, it handles snow/ice like a champ. Would GT350 be doable with decent winter tires and some sand bags in the trunk - or too much of a handful?
cheers
cheers
blckzed06 said:Thanks, guys. The issue is I don't have the space for a cheap winter beater, so looking for a car that can handle it all while being tons of fun.
JAJ said:I'm going to get flamed for saying this but if you keep the revs down, driving the GT350 is about as drama-filled as driving a Honda. There's more than enough low-end torque to get around and it's very controllable. For winter, just throw a set of narrow-ish blizzaks on it and keep going. Narrower wheels in 9" or 9.5" with 255/40x19 fronts and 265/40x19 rears give you better snow performance and are an exact match for the speedometer.
blckzed06 said:Thanks for the detailed response and suggestions! Are the above specs the narrowest tires that would fit? Also, would 18" wheels work, or would they not clear the brakes?
If I go with a GT350, I will definitely have a dedicated set of rims and tires for the winter - so want to go as small / narrow as possible.
JAJ said:As far as I can tell, both the front brakes and the rears are too big for 18's and there are probably lots of 19" rims that won't fit either. I have a set of 9.5x19 TSW's on hand (left over from my 2011 Mustang GT) that clear the brakes, so I'm probably going to run the 255/265 combo on them for the winter.
Alternately, you can ask someone that actually knows the answer: the GT350 owner's supplement says "Please call the Ford Performance Info Center at 1-800-367-3788 for specific winter tire recommendations." Maybe give them a call and see what they say.
302BOB said:I, personally, would never drive a car like the GT350 in bad weather, especially snowy/icy conditions...I don't care if I had a truckload of Blizzaks standing by. It's a race/track car not a snowplow. I don't even take my Boss out in the rain...but, hey, that's just me.
blckzed06 said:The issue is I don't have the space for a cheap winter beater.
It's just under 5". You've been there and know the downfalls so I say go for it. The 350 is a riot to drive and you won't be disappointed. As I mentioned previously the TC programs are significantly more advanced in the S550 vs S197 cars and should help you in your goal. Good luck!blckzed06 said:In terms of clearance, I currently have ~ 5 inches at the front lip. Do any of you guys know off-hand what that is for GT350?
VoodooBOSS said:It's just under 5". You've been there and know the downfalls so I say go for it. The 350 is a riot to drive and you won't be disappointed. As I mentioned previously the TC programs are significantly more advanced in the S550 vs S197 cars and should help you in your goal. Good luck!
Oh and post up some photos of your track car.
https://trackmustangsonline.com/index.php?board=9.0
