captdistraction
GrumpyRacer
;D
So I have a few things to install should I get the car back today:
Whiteline LCA relocation brackets
MM Panhard Bar (which might just be temporarily installed, it is indeed a rod end on either side, probably way too much for street - NVH)
J&M polyball LCAs (really interesting 3 different durometer bushings)
and (ordered today) Steeda front Boss-comp LCA's with their balljoints and poly bushings
On the whiteline LCA brackets, it seems there's about 1/8" of gap with the arm set in:
with the arm set in (the bushing cups want to push out to fill the gap, obviously not ideal
I bought some fender washers that are approximately the size of the bushing face and also would allow the bolt but not the crush tube through. I'm guessing I should use at least a pair to fill the gap, do I need to grease both sides to prevent any noise? Any thoughts on the plan there?
I think the rest of it will be cake outside torquing the suspension while loaded, that won't be fun.
Then on the front LCA's, it again looks to be a straightforward install, remove the spindle from the balljoint, remove front and rear bushing bolts, but anyone run into any issues or tricks?
