1 old racer
Too blessed to be stressed and old track whore,
Just finished a 6 week cooling upgrade. Things like this usually dont take me this long but it kept growing. I decided to add an inline trans cooler I contacted Mishimoto and they dont make a direct fit Auto trans cooler for the 2018 auto. So I re purposed two Fluidyne trans cooler I had from a old off road truck, I had that would fit the space I wanted and it was free (dont worry it was flushed cleaned and pressure tested it.). While it was out getting pressure tested and cleaned I ordered a oil cooling kit from Mishimoto and while I was waiting for that to arrive I figured I would a get new grill, I mean after all I had the front bumper off so why not. So I ordered a MP top and bottom grill set from AM. they all got here and I went to work. Installing the oil cooler was not as easy as I thought it would be but it went in as the instructions said it would. The Trans cooler took some fabrication in the form of brackets I drilled and taped into the crashbar and installed it just below it. I hope some day someone will make a dipstick to the trans. OMG what a pain to check and fill that thing. I could not check it hot so I checked it at room temp and when I installed the cooler I pre filled the cooler and rechecked it cool and filled it I gotr it to the same place. Then came the grill. I did not like the no screened opening of the top grill and i removed the solid side sections of the bottom grill. Then I ordered some ABS grill mesh from ebay and cut glued it into the openings. Perfect if I must say so myself. In the middle of this project I forgot to take photos. And I must give credit to lil Zeus for the fitting detail. Anyway the only photo I have is the finished photo of the grill. so here it is
