Cortex diff cover instructions
Discussion in 'Drivetrain, Exhaust and Electrical' started by docs302, Apr 19, 2019.
  1. docs302
    docs302 TMO Race
    380
    191
    Dec 31, 2014
    Philly
    Does anyone who has installed the Cortex cover still have the instructions handy? I lost the instructions and Cortex hasn't answered email or message. I would really like to get it done tomorrow. I just need to know the specs for tightening the cover bolts, bearing cap bolts and special sequence if there is one.
  2. TMSBOSS
    TMSBOSS TMO Addict
    4,154
    1,258
    Aug 23, 2011
    The instructions for the watts link should have the cover install instructions within.
  3. docs302
    docs302 TMO Race
    380
    191
    Dec 31, 2014
    Philly
    The watts link instructions basically say put the cover on according to the instructions that came in the box with the cover. Nothing specific. I remember reading much more detail in the instructions that came with the cover. There were specific details about the bearing cap support bolts and how much torque is required.
  4. Pitt302
    Pitt302 TMO Advanced
    114
    11
    May 30, 2013
    Pitt Meadows B.C. Canada
    1. Use Ultra Grey High Temperature Gasket Maker, Do not use a gasket. Make sure to use thread sealant. Back load bolts out to clear the bearing caps but do not remove them .Bolt & washer. Diff cover 25 FT-Lbs.Max. Screw the two load bolts in by hand until they make contact with bearing caps. Torque the load bolts to 5 Ft/LBS ( 60 in/lbs. ) Max. then snug the jamb nuts to lock the load bolts. Wait for sealant to cure before filling , fill until it comes out factory fill hole , approx. 3.25 quarts. Also torque in stages maybe 12 ft/lbs , then finish at 25 Ft/lbs. tighten it like a wheel , you cant go wrong.
  5. TMSBOSS
    TMSBOSS TMO Addict
    4,154
    1,258
    Aug 23, 2011
  6. Pitt302
    114
    11
    May 30, 2013
    If your installing a Torque Arm the 5 lower bolts will be replaced with new longer 5/16"-18 x 1.75" bolts.
  7. Coz
    Coz TMO Race
    370
    275
    Mar 4, 2018
    Philly Metro Area
    Not sure if the Watts link cover is different due to the loads on it but the LubeLocker diff gasket had been leak free and a LOT quicker & easier.
    Grant 302, steeda5 and TymeSlayer like this.
  8. Coz
    Coz TMO Race
    370
    275
    Mar 4, 2018
    Philly Metro Area
    Unless you have a diff catch can, I would recommend filling to 1/4 inch below the factory fill hole. Otherwise you may have the typical fluid leak from the axle vent.
    I use a zip tie with about 1/2-inch of the tip bent 90° as a dipstick.
    TymeSlayer likes this.
  9. docs302
    docs302 TMO Race
    380
    191
    Dec 31, 2014
    Philly
    Thank you everyone. That's what I was looking for. I do have the Cotex diff breather set up. I was going to use the LubeLocker gasket that I currently had but Kurt at Phoenix told me not to and also recommended the Permatex Ultra Grey which I have. Looks like I'm ready to go.
  10. TymeSlayer
    TymeSlayer Tramps like us, Baby we were born to run...
    2,715
    1,395
    Dec 12, 2011
    Brighton, Colorado
    Nothing wrong with the lubelocker as I've used it twice with no issues whatsoever.
  11. TMSBOSS
    TMSBOSS TMO Addict
    4,154
    1,258
    Aug 23, 2011
    Is the concern with the lubelocker and the watt that the cover may move a bit? Silicone may limit movement better.
  12. Coz
    Coz TMO Race
    370
    275
    Mar 4, 2018
    Philly Metro Area
    Here is something that covers the torque sequence. The Drake cover is like the FRPP cover.
Share This Page
