At the Las Vegas 50th celebration Filip from CorteX told me about two interesting new products that should be available soon. Hopefully he’ll drop me a note when they become available.
First is a complete double wishbone front suspension. This will be a complete bolt on kit that will require drilling a few holes on each side of the car. It will use the JRi dampers used on the rear so all four dampers will be the same size. This kit has been tested and is in the final stages of production.
The other is another level of JRi dampers that are single adjustable instead of the current double adjustable. This kit will adjust both compression and rebound with one adjuster. This kit will knock approximately $700 off the price of the double adjustable dampers. They will also be upgradable to double adjustable should you desire that in the future. From my conversation with JRi at SEMA last Fall their product offering appears to be a hot setup at this price point.
http://www.cortexracing.com/shop/xtreme-grip-coil-over-system-jri-double-adjustable/
http://www.cortexracing.com/shop/xtreme-grip-coil-over-front-struts-jri-da/
