- 158
- 3
I'm about to do my 2nd HPDE this year (and 3rd ever)......just a couple of quick questions - so I can get better at these track days.
1. How much do tires increase pressure when getting hot. It seems the tire should be at 41 psi at the track; so what should the tire be cold when starting? The tread on the tires look good - as they start to wear out - do they wear on the sides from cornering or just on the tread....
2. I changed the oil just before my last HPDE, 1 day event, and have driven an additional 300 miles (probably 500 total)...should I change the oil again before the next event?
3. I also put in new dot 4 brake fluid before the last HPDE; should I bleed the brakes...or is it usually fine?
I have about 6800 miles on car - are there any other oils or things I should flush or change before or after this event or after a track event.
I appreciate the help.
