Custom Tuning
Senderofan
Hey Guys:
Most of us are looking for advice....or recommendations for tuners for our vehicles. I have a 2013 Boss Mustang. I'm changing to an AirAid CAI, a FRPP 84.5mm TB, FRPP 47 lb fuel injectors, O/R X pipe and GT 500 axle backs.
These are common upgrades....and I'm here to tell you that Shaun can help!!!!!!!
Wayne
Are you planning to dyno it so we can see some #s on that setup Wayne? Would love to know what it produces. Did you tune for E85 that you needed to upgrade the injectors?
I'd like to see a dyno also -e85, no idea where to find it around here. Looks like the same setup as mine with the exception of the injectors
I'm 40 miles from their shop but I'm sticking with stock at least for now. I'd like to see a dyno chart as I have some of the same mods.
Senderofan
Gary:
There is a portable dyno that comes to this area from Watertown, SD. I think their handle is Dyno Tuners USA. Anyway, I've got feelers out to let me know when they come to this area....usually July. I'm hoping to see what their dynojet reads. Sad deal is...I won't have a stock pull to compare to.
Injectors....Yes....In the process of installing the LU47 FRPP injectors as we speak. Just needed to figure out how to remove the foam bits and fuel rails. Hopefully have it buttoned up by late tomorrow afternoon...including the larger TB and Airaid cai.
E85 tune will come after we get the 91 octane tune sorted out. I'm really looking forward to the cooler cylinder temps that the E85 brings. Hoping to have all catalogs and tunes worked out for my first track date...May 19th. Going to be tight...but hopefully we'll make it.
Wayne
Senderofan
Living that close to AED is an extremely valuable resource for you. If/When you decide to mod.....it would be great to have Shaun tune your vehicle in person.
Wayne
Senderofan
I think, in the many correspondences I've had with Shaun, he reports that I should get about 15 additional hp by running E85. Biggest thing for me is the cooler cylinder temps and resistance to pre-detonation. Would like to keep this motor "Happy"....but I'm worried about cyl. #8 and the high temps on the track.
My problem in this area....I cannot find fuel above 91 octane. Would be nice to try a 93 octane tune.
Wayne
Senderofan
Would have had everything buttoned up this afternoon......but the 45* silicone elbow from the TB to the AirAid is too small. I thought I had read a reply from someone that stretched it to fit the 84.5mm TB....but being 38 degrees today....I couldn't stretch it...so a new 4" ID and 4" ID opening 45* elbow is inbound. BTW, my oem tb did not have a spacer.
Doing the injectors was interesting. They must have a powertrain engineer that played with a foam Gumby and Pokey while growing up. Never have I seen this weird foam in amongst an engine. Drivers side has a few fiddly bits to contend with. I removed the oem cai and throttle body before removing the rails / injectors as a unit. I managed to mess up on a great tip that Pufferfish gave me.....to run the fuel out of the rails. I pulled the fuel pump fuse before I tried to started the car....instead of when it was idling. So.....you'd be amazed at how much fuel is in the two rails :) :)! Doh!
Wayne
Justin
Wayne
boil some water and heat up the silicon coupler. It will stretch that way
Senderofan
Thanks...Didn't think of that....Great tip. Should have waited for such a tip before visiting Summit Racing :(.
Wayne
