DB levels on aftermarket exhaust
Hi Guys
when running on tracks in the UK we cannot exceed 105DB (measured at 75% revs at 1mtr down from the pipes.
Obviously in stock it passes easy, i have a 2011 GT with roush axle backs thats just on the limit but sounds fantastic much better than the boss
Ive taken the plates out and it still doesn't sound as good as the GT
what exhausts are you running and what DB limit are you reaching?
I don't have it measured, but you should be okay with '11 or '12 GT500 mufflers. Have those on my GT sound good, but not as loud as the Roush AB, which I've heard in person.
I passed a 92 dB limit with 3/4" discs on the Boss at Laguna Seca.
Thanks Grant
The Roush do sound so good though!
ill find some GT500's, im planning on buying the electronic switches for the side pipes so i can kill that side of during the test
ian
I passed with my 7/8" discs and GT500 mufflers. I think I'd pass at the 90db level too.
You see this is my quandary
My 2011 GT has Roush Axle backs and its sounds fantastic, everybody loves the sound but i think its just over the limit on some tracks so i need something with less boom but a great sound.
It sounds like the GT 500 may be to quiet!
The GT500's are quite a bit louder than stock after they have a couple of hundred miles on them. The db level Grant and I are referring to is on the track between turn 5 and 6 at Laguna Seca and the sensor is a ways off the track. So not the same as you described. You should install the Roush axelbacks and take some different sized restrictor plates with you in case you don't pass. Maybe order up 1/2" and 3/4" and keep them in your car when you go to the track. Takes 15 minutes to install them.
Im going to put the electric cut outs in the side pipes so no problems there i can then open/close them to suit
its just a choice of the rear boxes:)
Justin
I'm surprised the corsa fan boys havent recommended their mufflers...no drone light weight outrageously expensive
http://www.latemodelrestoration.com/item/CSE-14317/Mustang-Gt-Corsa-Extreme-Axleback-Exhaust-System
[youtube]http://www.youtube.com/watch?v=aJEFJeMD7uo&feature=player_embedded[/youtube]
8,068
7,748
Thanks Justin, I was going to jump in with the Corsas, but you beat me to it. Pricier than some , but the only ones I know of that dyno for power and sound, plus made in the US, not sent overseas and then mailed back.
No packing , so virtually no rust through issues.
Justin
I am not worried about rust on my magnaflows as they are made of stainless steel. I think most big name exhausts are made of stainless these days.
When I go with long tubes I may have to go back to something else as they probably will be way to loud.
