Dead battery
drano38
Wayne
1,130
318
After you get a new battery under warranty, I'd call Battery Tender, and politely ask them for a new one also.
Hopefully everyone cooperates with you for your problems.
jneary
Performance Fords
323
Norcal
More than likely nothing wrong with the tender if the battery has a bad cell. If there is a defect in the battery, there is nothing the tender would have done to cause the failure. Just have ford put a new battery in it.
Every Ford battery that I have had has gone at least 5 years and more like 7 without a problem. You have a mfg defect.
John
when its time for me to get a battery I think I will be going with this one.
http://www.amazon.com/Odyssey-PC1200MJT-Automotive-LTV-Battery/dp/B002496GK8/ref=wl_mb_cm_go_shovrw_2_dp?ie=UTF8&colid=3QS6D7NK5UWI0&coliid=I1QG7AWRUGDHMD
According to the specs it weighs 40 pounds, your stock one weights 31. Are you putting it in the trunk for ballast?
if you want light I would go with this
http://www.performancedistributors.com/batteries.htm
now that they have a I think I will go with this battery
