Has anyone added the diff temp sensor to their GT? I know the Dark Horses come with them, I installed the sensor and ran the wires, but I can't figure out where the two wires lead after going to the connector c264 in the driver-side footwell.
You already sadly spent the money but adding a mechanical gauge would be simpler. Same port in the cover just needs to be drilled out with 3/16" bit and a metric to 1/8" NPT bushing added. I am guessing you don't have a Performance Pack car as I thought they all came with it as well as Dark Horse cars.Has anyone added the diff temp sensor to their GT? I know the Dark Horses come with them, I installed the sensor and ran the wires, but I can't figure out where the two wires lead after going to the connector c264 in the driver-side footwell.
There might be a way to read the diff temperature on a Performance Pack car with an OBD scanner but my car doesn't show me diff temperature on the dash. If the diff gets too hot it will flash a warning. Although that hasn't happened a single time on my car so I'm not sure it even works.You already sadly spent the money but adding a mechanical gauge would be simpler. Same port in the cover just needs to be drilled out with 3/16" bit and a metric to 1/8" NPT bushing added. I am guessing you don't have a Performance Pack car as I thought they all came with it as well as Dark Horse cars.
Is there a factory sensor on the car? If so I can't imagine there isn't a way to get it on the dash. Not available in Auxiliary Gauges on the center screen?There might be a way to read the diff temperature on a Performance Pack car with an OBD scanner but my car doesn't show me diff temperature on the dash. If the diff gets too hot it will flash a warning. Although that hasn't happened a single time on my car so I'm not sure it even works.
The sensor is there but there is no gauge in any of the menus.Is there a factory sensor on the car? If so I can't imagine there isn't a way to get it on the dash. Not available in Auxiliary Gauges on the center screen?
