hey...i recognize that car
pufferfish said:i was talking to a BOSS owner at the track a while back and he mentioned that he heard that installing the Laguna Seca splitter without the LS rear wing, would unbalance the car. he didn't know in what respect, uneven grip front to rear in corners or instability in a fast straight.
can anyone verify this? i just bought the LS splitter for fitment testing on my tow bracket and intended to install it for the track, but i only have the little lip spoiler. i have a track event in 2 weeks i wouldn't mind trying it out on, but i don't want to make the car handle worse and end up in trouble.
PeteInCT said:I'd be curious how accurate it is. There's a lot of little 'gotchas' on that track.
Don't let Gary see that.PeteInCT said:Thanks Steve. Check this one out:
http://www.summitracing.com/parts/LAK-30301/?rtype=10
It has a nifty way to connect the stock battery cables. It's the only one I've seen that has that....
2012YellowBoss said:I will throw my two cents in here.
The splitter adds down-force to the whole car, not just the front, because it sends a direct airflow under the car without turbulence at high speed. This creates a low pressure which pulls the entire car to the ground. That is why lowering the splitter makes a big difference, less air has to be "split" and sent underneath creating a better low pressure.
2012YellowBoss said:Saying that you could point the splitter down and that would add down force only on the front of the car or the opposite pointing it up and it would take away the down-force forcing it up. Neither of these is what a splitter is designed for.
2012YellowBoss said:The front of the car will create a high pressure as you move forward creating drag. I'm not sure that air in front of the car has anything to do with creating or taking away down force. Then the air then passes over the hood at a faster rate, again creating a low pressure which will want to lift the car up. This combined with a pressure build up (high) under the hood makes for even more lift. The air then passes the windshield, high pressure again, adding down-force only because of it location and over the roof where again it is fast and low. This is one reason NASCAR added the roof flaps to break up that wind so it does not create lift when spinning, it has worked very well.
2012YellowBoss said:So going back to the original question, yes the car will not be balanced like Ford wanted it. I am sure they did wind tunnel testing. I doubt it would be to the point of dangerous and unless you drive like Joe Foster I would guess most of us would not really under understand the difference. Still it would be best to have the splitter and spoiler working together just like adding the Tiger hood would be better with a taller spoiler even if it works fine for non-professionals like myself.
pufferfish said:well, i picked up the LS rear spoiler and got it on with little trouble. then moved to the front to install the LS splitter and bolt holes arent anywhere near where they should be. there's also a set of contoured pieces bolted to the top of the splitter that don't line up with any of my bodywork. so, i went to the track without the splitter on
i am wondering if i got a 2013 LS splitter. i can't find any pics or install instructions for it to determine if that is what i have. does anyone have one here that they can add pics of (not installed) so i can confirm? i belive i may be stuck with it as i bought it on ebay and they say "no returns", but it is clearly not the part number they sold me. i contacted them, so we will see.
