DSC Tractive coilovers
Ive seriously been considering DSC Tractive
Coil overs for my 2016 GT350 track pack.
As of now my car is fitted with the following.
Forgeline GA1R open lugs 11x19
305/30 PSC2
Eibach front and rear sway bars.
Delrin sway bar bushings front and rear.
Cortex front and rear adjustable sway bar end links.
Cortex front and rear control arm monoballs.
Vorshlag camber plates.
Ford performance toe bearings.
Ford performance IRS aluminum cradle bushings.
Ford performance differential aluminum/delrin bushings.
Self made vertical links.
Self made adjustable toe links.
Voodoo13 adjustable camber links.
QA1 carbon fiber driveshaft.
Watson roll bar.
R splitter.
R rear seat delete.
I also removed 130 pounds from the car and more weight loss to come.
My question about the DSC Tractive coil overs are they offer RTx and RTx plus. I can not find anymore info on this set up for our car. I looked everywhere and no luck. Does anyone know if or when they will be available? Nearly 2 years ago I talked to someone at DSC and they mentioned the coil overs back than but still no news.
I know I can still use the DSC mag controller, but also I’m curious as to what the weight loss is and cost on the system.
What options are available and when will they be available to buy?
