- 1,172
- 2
I would think if you haven't changed the geometry then there would be no need to check your pinion.
Brandon302 said:I would think if you haven't changed the geometry then there would be no need to check your pinion.
with the dss shaft no its part of its selling point having the cv joint at the tail end vice a typical joint used in driveshafts.WinterSucks said:For those who install a new shaft with stock suspension (not lowered, no adjustable components), does the shaft angle need to be checked? I am in that situation and so far so good, but I don't want to get a DS in the butt by not installing an adjustable upper.
Justin said:with the dss shaft no its part of its selling point having the cv joint at the tail end vice a typical joint used in driveshafts.
Flyboygsxr said:So my driveshaft gave out yesterday...I was on my way to the Nurburgring with my buddy and I started to get this weird vibration. It was random and would come and go and I wasn't sure what it was. Finally the car started to vibrate so violently that I had to pull over and could no longer drive the car...not even in first gear at 5mph. It was so violent it shook every part of the car and if I hadn't been going so slow I might not have been able to control the car. There was a metal on metal grinding sound that I thought for sure the driveshaft had come apart. I couldn't get under the car to see because I was on the Autobahn. I had to pay about $700 for a tow back to my house...5 hours in a tow truck sucks. I got the car up on the lift the following day and I could see nothing wrong with the driveshaft. There wasn't a mark on it and everything looked fine. With all the grinding noise I expected to see damage. I checked everything, pinion angle, made sure all the bolts were properly torqued and everything was perfect. The car was up on a drive on lift with a separate sliding lift so I could lift the rear and get the wheels turing to see what was going on. I had a friend get in the car and put it in gear and get the wheels spinning and sure enough the grinding and shaking was still there. Even though I couldn't see any damage I think the U-Joint failed. It almost sounds like there is grinding going on inside the driveshaft like something failed inside but I am almost 100% sure it is a problem with the U-Joint. I will be contacting Lethal Performance as I ordered the driveshaft through them. It had less than 3000 miles on it and up until it failed it was smooth as butter and I loved it. I have never launched the car and I do not drag race. It just failed while I was cruising down the Autobahn (freeway). I'll keep you guys posted on what Lethal does about the issue. I hoping they refund my money completely as I am probably going to stick with the stock shaft for a little while longer. It is a lot heavier but it is smooth. I am also worried about warranty if an aftermarket shaft fails. I have the stock driveshaft back in and everything is fine.
racered302 said:Good to know considering I'm waiting on mine now. I hope it fall's in the middle of the measurement they give. Does the measurment change when the car is lowered? I know the pinion angle changes but wouldn't the distance change too?
Flyboygsxr said:The distance does change and it changes every time the suspension compresses and rebounds. That is why it's safer to keep the measurement in the middle of the tolerance.
TymeSlayer said:Just another update on my DSS driveshaft.
I have re-installed it and added the BMR safety loop. There was nothing wrong before but since I started hearing of some failure issues, I took it off until I could get the BMR installed. I have had no issues whatsoever since the re-install and love the feel of this DS. The weight saving is a plus as well.
Champale said:+1 on the Dynotech that Steve at Blowfish sells. Fantastic quality, zero vibes, actually reduced the diff whine that was coming through my Steeda UCA and bracket.
I have read of far too many weird issues with the DSS shafts on this forum and others and am very glad I didn't believe the early hype.
