S550 Dyno plug
5
Drag Strip
Canada
The s550 so called dyno plug
4-wire pin connector into a plug cap w loop green wire.
We have lost the dyno plug cap.
Anyone know what 2 wires on the 4 wire harness side connect ? When the cap is installed. Im going to install a switch in the cab. Will allow to either close the circuit or open the circuit for stability and traction control off.
The 4 wires are
1- solid green
2-green w yellow trace
1-gray
What 2 wires connect when cap is installed
Thanks in advance
81
94
Scottsdale
Are you talking the plug on the drivers side front fender near the air box? If so, that plug is for the advance track. You can pull that cap to turn off all the nannys for the track I have heard. Have not ever tried.
5
Drag Strip
Canada
Yes thar is the plug.
yes
That is the plug. Looking for what 2 wire colours on the harness connect once the plug cap is installed
Thanks
