Most would say Leave it off. Saves a little weight and eliminates the risk of application after hot laps causing pads to stick (although this is less of a risk with the GT350 drum e-brake).
I left mine on solely for the purpose of locking it down in the trailer.What would the recommendation be for a dedicated track car regarding the need for e brake? Leave it off?
Thanks Nick. Need to figure out how to remove the pedal assembly. The throttle is easy. The brake and clutch is my next task. All bolts are off.
Removing the pedal assembly is easy. I removed mine to drill and tap my clutch and brake pedals in my mill. It’s a little awkward as always working under the dash but not to bad. You can remove the whole pedal box in about 30 minutes. Another plus is, you will not have to remove the clutch slave cylinder.
